pola bear
VR6 coilpack, correct firing order?
all was fine till i took the leads off, after putting them back in its misfiring like crazy. is this configuration correct?
Errr... you've got two 2's on the coilpack...
Not sure off hand but I take it you realise the Coilpack points are numbered as are the cable clip trays so you can't really go wrong...
Nope, thats wrong.
Plug 1 should go to your No 5 on the coil pack; and plug 5 should go to your No 1 on the coil pack. ie 1 and 5 need swapping over. Make sense?
