andy.b
Temp gage and Fuse Realy's
hello lads, corrado VR6 qestions here!
Some wanker pulled the fuse box wires out of my fuse box while installing an alarm. Since then my temp gage on my clocks stoped working, i bought some new clocks and the temp only went to 70 degrees and this has been going on for 3 months.
so i thought this was the sensor on thermo housing causing the problem.
before i managed to get my temp sensor fixed two weeks ago the clocks started to work correctly going to 90 degrees normal running temprature.
"i thought fucking nice one, thank fuck for that"
then,
today i blew my fuse for the central locking and elecwindows, i replaced the fuse "the one rite up in the dash" and i had to move alot of wires carefuly. when i started my car and thrashed it round for abit, i noticed the temp gage was only going up to 70 degrees again.
is this a wiring job for VW or do you no anyone in the wigan/chorley area that will sort this problem?
P.S. the fuse relays above the fuses, can someone explain where relay boxNo 99 goes because in knocked it out.
