andy.b
CAN THIS BE DONE
MY TEMP GAGE IS NOT WORKING CORRECTLY BECAUSE OF BAD WIREING, I THINK A WIRE IS BROKEN OR A WIRE IS EARTHING OUT SOMEWERE AND ITS CAUSING MY TEMP GAGE NOT TO WORK CORRECTLY.
CAN VOLKSWAGEN RUN A WIRE FROM THE YELLOW SENSOR ON THE THERMO HOUSING AND CONNECT IT TO THE RITE WIRE IN THE PLUG THAT GOES IN THE BACK OF SPEEDO CLOCKS?
WILL THIS WORK IF IT WAS BAD WIREING TO BEGIN WITH?
