VEEDUBBED
G60.16V
Hello all,
I'd like to know if i
have to use the black temp gauge(Digi G60)
sensor in order to operate the cluster
gauge or could i just use the original
9A's 16v sensor on the head?.
What about the 9A's original ISV,
can it be used in place of the G60's valve?.
Any help is always apriciated.
Cheers.
is the cluster you are using from a 16V if yes then use ure own, if no use the G60's. if the part number on the ISV is 037 906 457 D then yes you can, I have been running an 037 906 457 C on my corrado for about a year now, it just doesnt have the computer controlled blow off valve in it, and I have rerouted mine, despite what these guys say, I still have a BOV tho so =-).
you probably have 034 133 455 B or 048 133 455 as an ISV, these wont work sorry. also did you use a 16V block or a G60 block to do ure conversion. or did u just slap on a G-ladder to a 16V?
The engine's a 9A
2 liter 16 valver,
I've got all the ISVs
off all models to try,
i was just curios.
The cluster is off a Corrado VR6.
