vwcvr6
Possible coolant leak
hi guys i got a small prob!
am not sure where its leaking from all i know is the floor is wet after i park it. i can c patches of liquid in the engine bay!!!
managed to get a pic where i tink it leaks and i havnt got a clue what needs to be done
any help will be appreciated
:? thxs
k
vwcvr6 that's the auxiliary water pump. IF that's where its leaking, it'll either be from the hose connections or the plastic fitting on the bottom of the pump body. To get at it you'll have to take the end cover off the top of the engine. The pump is held on by two rubber mountings fitted to bracket bolted (3x10mm) to the top chain cover. PM me if you want some pix of it all in bits & how to get it apart.
can any pls tell me where i can buy an auxiliary water pump and how much will is cost!! its got a massive leak!!
thxs storm!!
is it worth getting a used one or am i better off buying a new one!!
Am planning on changing the coolant to g12 at the same time
has any1 done this themselves and is it easy to do
sorry but i havent got a clue on how to do it!!!
thxs
