SteveM16v
Which relay?
Hello,
Anyone know which is the relay for the sunroof?
The sunroof has no power going to it (I checked by turning on the ignition and interior light and then pushing the sunroof button) and I think it must be a relay, as there doesn't seem to be a fuse for it.
I've found that one of the relays (light blue in colour) has slight staining on one of the plug legs. I think the number of the relay is 63 or 67 - could it be this one?
Thanks as always
Steve
I think the sunroof is not connected to any relay check fuse no 4. I hope this helps.
check the secound relay(secound one above fuse no 6) and also check if there is a lose ground connection beside the relay panel other than that it is either your sunroof motor is fried or the sunroof switch is bad....
The sunroof IS connected to a relay because the heater and sunroof share the same relay.
Cant remember which one it is though, check the grey one (number 18 IIRC)
