rossy t
fitting H&R springs to koni adjustable shocks
to solve the crashy ride on koni adj shocks & springs thats doing my nut in i just bought some H&R springs from NFS to be delivered shortly. after a good old search of the forum i have uncovered some threads about VR6 owners having to get new top plate mountings for the front?
seeing as i own a 2l 16v will i have to get these to make them fit?
what other components should i buy from GSF / VDub to replace at the same time while the garage is working on the car?
im getting there slowly :lol:
Depends what year your car is. H&R only make the springs with the larger top coil (early top plate). If your VR is a 92 or 93, you may not need the top plate. If you've got a 94 or 95, then you will.
