chrishill
bush part numbers needed from ETKA
I'm in need of a hand with some part numbers for the various bushes across all models so I can sort out the powerflex group buy. would someone with ETKA be so kind as to them up for me? Ideally as many as you can list off would be great as the group buy isnt limited to specific bushes, but in particular I'd like to know:
Front ARB mounts to Body
Front Wishbone Front Bush
Front wishbone Rear Bush
Rear bush (OEM allows flex for PRS, not sure what the correct name is!)
for all models!
Cheers in advance.
here you go m8
front wishbone/front is 357 407 182
front wishbone rear is 191 407 181e
ARB inner are 191 411 314
now etka calls these bearings but they are the bush that goes either side of the wishbone on the droplink from the ARB 191 411 329.
these are all listed for KR,PG,9A,2E AND ADY.these all look to be the same part numbers for the ABV aswell
rear bush's are 191501 541 KR,PG,9A,2E AND ADY.
1H0 501 541A FOR ABV
