timmyhol 0 Posted April 20, 2005 I keep reading that the fuel tank is 77ltrs or 15 gallons. I have run mine to the top of the red area and then filled the tank until the petrol station pump clicks. The maximum I have put in has been 35ltrs and the fuel gauge in the car shows the tank is full. I can only seem to get approx. 220 miles out of the tank which is about 30mpg which is good, but the tank seems to be only 7ltrs!!!! so......I presume the 15 on the fuel gauge is talking about 15 gallons, but I can only fit in 7???? am I going wrong or is something not right. Any help would really be appreciated as Im seriously confused. Thanks Tim Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 20, 2005 The tank size is 70 litres (15 Gal) on VR6s and later G60s, and prob late valvers etc but otherwise it's 12 Gallons. Could be the guage assuming there's no blockages in the tank which keeps triggering the pump shut off. Quote Share this post Link to post Share on other sites
dinkus 10 Posted April 20, 2005 It sounds like the float on the gauge is catching/stickin on something. You can have a look in the tank to have a check. Open boot, remove carpet Remove screws and round panel to access top of tank Use a cold chisel/big screwdriver and a hammer to unscrew the ring around the top of the tank Pull out the gauge and shove yer arm in (watch out, it'll be cold! :) ) Have a feel to see if the float (like a coat hanger) is caught on anything Obviously best not to smoke during this process and I'd do it when there's not a lot of fuel in the tank. Quote Share this post Link to post Share on other sites
timmyhol 0 Posted April 20, 2005 Cheers for your help guys. I'll have a look in the tank this weekend and see whats going on. Tim Quote Share this post Link to post Share on other sites
