surfer.vr6 0 Posted May 4, 2005 just completed renewing timing chains, guides and tensioners head sent off for skimming renewed clutch everything ok but now have noisey tappets could the head being taken off and sent to get skimmed contributed to this? are they worth changing or is it worth bothering about any ideas? Quote Share this post Link to post Share on other sites
andy 0 Posted May 5, 2005 I'd definately change them, I didn't when I had the head off my old Golf and regretted the slightly noisy tappets forever afterwards. Not that expensive from GSF. Quote Share this post Link to post Share on other sites
tonytiger 0 Posted May 5, 2005 I've read that some people have found that the GSF ones sometimes don't last too long, and end up being just as noisy (or noisier) fairly quickly. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 5, 2005 I'm getting a price on VW tappets later as GSF (Febi) ones are definitely not too great.... Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 5, 2005 I'm on my second set of GSF tappets and am not entirely happy, either. VW ones are around twice the price though. Quote Share this post Link to post Share on other sites
Geo 0 Posted May 5, 2005 When I was rebuilding the engine in my vento I didn't replace the tappets and they are slightly noisy for a few seconds from cold, bit annoying but I'm not stripping it back to do them now! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 5, 2005 "noisy from cold" is fine and dandy. "noisy all the damn time" is not... :( Quote Share this post Link to post Share on other sites
Geo 0 Posted May 5, 2005 LOL, I'd agree with you there alright. Quote Share this post Link to post Share on other sites
H8RRA 0 Posted May 5, 2005 in the peter russek book, theres a procedure to test the tappets - most times this procedure seems to resolve any tapping - if not they need replacing. From memory, you warm up the engine and sit at 3500rpm for 3 minutes - strangely this has resolved most tappet noise problems i've had. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 5, 2005 In other words drive at 80mph for 3 minutes? I cant see why doing that in neutral would be any different? It would be embarrasing aswell! OK, tappets from VW are £17.33 + VAT each, bringing the total to £244.35 inclusive for 12 of the buggers. I can get them for £195 all in, but I still ain't paying that just to see if it 'might' resolve the tapping! I wonder if they'd be cheaper from Ford? Quote Share this post Link to post Share on other sites
RW1 0 Posted May 5, 2005 Hi, When you had the head skimmed, did it get "cleaned" properly afterwards. If not, the the small arteries may have become blocked with small "bits" or the bits are now in the small feeds in the tappets themselves. Fitting new tappets may only last a while if the oil feeds are not clean. The other thing to check is oil pressure. 2 bar (30psi) at idle and 4 bar (60psi) at 2,500 rpm plus as a guide with the engine warmed up based on 15w40 oil. May be be worth just using flushing oil to see if it will free up the tappets. If not and oil pressure is OK, then you know it's a tappet replacement job. Quote Share this post Link to post Share on other sites
surfer.vr6 0 Posted May 5, 2005 thanks for that rw1 i will try to flush the engine Quote Share this post Link to post Share on other sites
H8RRA 0 Posted May 6, 2005 In other words drive at 80mph for 3 minutes? I cant see why doing that in neutral would be any different? It would be embarrasing aswell! OK, tappets from VW are £17.33 + VAT each, bringing the total to £244.35 inclusive for 12 of the buggers. I can get them for £195 all in, but I still ain't paying that just to see if it 'might' resolve the tapping! I wonder if they'd be cheaper from Ford? As previously stated - i've found it works - can't get up to 80mph in my backlane after i've serviced the car so i'll stick to my method, Kev, rather thatn your 80mph suggestion :wink: Quote Share this post Link to post Share on other sites
