jenks 0 Posted May 5, 2005 Hey just bought a 92 2.0litre Passat Estate, Got coilovers for the corrado now so will my 55mm lowering kit off my 16v Corrado go on? Not looked yet cos not got car but does any1 know if mk2 golf/corrado suspension is the same? Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted May 5, 2005 Hmmm, not sure if the Corrado suspension will work - the rear should at least fit cos it's the same, but the spring rates will be all wrong due to the cars being different weights... IIRC the Corrado uses Golf II front suspension, so not sure if it's the same as the Passat... Sorry, just realised I've told you very little! :oops: Quote Share this post Link to post Share on other sites
jenks 0 Posted May 6, 2005 :lol: Its cool mate cos thats exactly what went through my mind, just wanted to check! im positive the passat subframe is the same as a mk2/corrado but wishbones are a bit wider, so i think it mite work? yeah being an estate it mite be different spring rates,loads,etc but heavest itl be is a pair of mountain bikes or an engine. Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted May 6, 2005 Yes be carefull with altering spring and damper rates and also ride heights; you can totally mess up the operation of the rear brake regulator valve. A Passat Estate has a very much greater rear overhang than a Corrado and a higher potential rear axle load as a result of this and its being a heavier anyway. Once one of those baby's gets it into its head that the back is going faster than the front, especially when braking downhill, you need to be quick to catch it. ("The Voice of Experience" has spoken). Strictly speaking, you need to tell your insurer that you have altered the suspension. Best wishes RB Quote Share this post Link to post Share on other sites
jenks 0 Posted May 6, 2005 cheers, so 55mm too low you reckon? What was yours lowered by? Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted May 6, 2005 I didn't lower it, but it is a bit stiffer than usual 4 cyl. Passats being a 16V GT ('94, LHD supplied im Germany, same suspension as VR6), and the back can get a bit wayward in the downhill/braking/heavily loaded scenario. Best wishes RB Quote Share this post Link to post Share on other sites
