Dennis.be
Got myself a Dyno run...
What do you think about this dyno?
EngSpd : 6665 RPM
ECETrq: 271,8CmM @ 3954 RPM
ECEPwr : 198,4Chp @ 5872 RPM
The spec's of the engine :
- RS chip
- 68mm pulley
- 236°/273 CatCams camshaft
- CatCams adjustable cam pulley
- 3.5bar fuel pressure regulator
- K&N replacement Air-filter
- New cilinder head (bigger in & out)
- G-lader remanufactured (1.1 Bar)
- Remus Exhaust
- Green injectors
- Smal intercooler
They say that I could have more if I had a big intercooler, that's what I already expected.
Catcams has more than 1 cam for the G60, even custom made.
I have not exactly an idea what the SAE was, I took the basic run.
Since this weekend I have a custom chip placed for my setup and hopefuly soon another dyno run on the same dyno.
The new chip has to bring the torque to 300Nm or above on the same rpm.
The chip comes from FH technic, this guy is very well known on the dutch corrado forum for his results on the most VAG engines.
http://www.fhtechnic.nl
