Dub Style
front suspension strut removal
Just need to check this with you guys, whilst the car is on ground undo the top nut with a swan neck spanner whilst holding the centre shaft with a allen key. jack the car up and undo the bottom bolts?
Make sure you get your camber and tracking done afterwards because those bottom two bolts adjust the camber ;)
I'd do it the other way round. Jack the car up, remove the wheel, undo bottom bolts, then undo the top bolts.
If you undo the top bolts first, you could end up jacking up the car for ages before the wheel lifts off the ground
Cheers
Steve
