chris g 0 Posted May 11, 2005 Bought a new fuel filter the other day, Where abouts is it so I can change it? Cheers Chris Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 11, 2005 Look under the rear wheel arch below the filler cap - it has a plastic cover over it... use new jubilee clips if it still has the VW originals on it. Quote Share this post Link to post Share on other sites
chris g 0 Posted May 11, 2005 Will do, thanks very much! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 11, 2005 If you need to cut the old bracket off, just use some long cable ties to fix it back on, they'll never rust :wink: Quote Share this post Link to post Share on other sites
retrodal 0 Posted May 12, 2005 Hi there, I also have just purchased a fuel filter, it it easy to fit or should I bring in the experts!!!! Cheers retrodal Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 12, 2005 It's an easy DIY job. Just make sure you observe the flow arrows when putting it back and I'd trim 5mm off the end of the rubber hoses as they sometimes perish, causing petrol smells. Quote Share this post Link to post Share on other sites
