chris g
Fuel filter
Look under the rear wheel arch below the filler cap - it has a plastic cover over it... use new jubilee clips if it still has the VW originals on it.
Hi there,
I also have just purchased a fuel filter, it it easy to fit or should I bring in the experts!!!!
retrodal
It's an easy DIY job. Just make sure you observe the flow arrows when putting it back and I'd trim 5mm off the end of the rubber hoses as they sometimes perish, causing petrol smells.
