EDSTARVR6 0 Posted May 13, 2005 The problem: If I lleave my car for 3-4 days it will not start (plus the digital clocks don't show and the central locking doesn't work). I know the alarm system is not the cause of the problems, but what could it be. Have you experienced this before? The car is booked in at an autoelectricians for Monday, but any ideas I can pass on might cut down the time they spend fault finding. thanks Quote Share this post Link to post Share on other sites
Reggit 0 Posted May 13, 2005 Possible an interior light staying on, boot or glovebox are possible culprits. Could just be a duff battery that's not holding its charge Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 13, 2005 1) Stick a voltmeter on the battery. 2) Use the search to find previous threads detailing this stuff.. ;) Quote Share this post Link to post Share on other sites
EDSTARVR6 0 Posted May 13, 2005 Cheers dude. Did search the Forum before, but used the wrong search terms me thinks. Will get a new multimeter, I think my £3 item from Maplins is shagged, and then start checking things. fingers crossed it's the boot light. ;-) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 13, 2005 Check the usual culprits then start pulling fuses out to find which circuit is the problem Quote Share this post Link to post Share on other sites
Igor 0 Posted August 9, 2005 Obtained from our American Chums at http://www.corrado-club.com "An additional entry for your known problems list. I have a 1990 G60 which has drained the battery when parked since day one. What I eventually discovered is that there is a power window relay control unit mounted to the left of the left rear passenger seat which has a connection to the door switches (why?). I observed that when the unit is first connected with the doors CLOSED there is no power drain. However, as soon as a door is opened a relay engages inside the unit (you can hear it click in) and from then on there is a consistent 100mA drain on the battery. You can only release the relay (and the power drain) by unplugging the power feed to the relay module. This power drain is not a problem if the car is driven regularly, but if you only use the car from time to time you'll be fighting a dead battery more often than not. My quick fix to this problem was to disconnect the wires which go to the door switches. Every thing appears to work fine without this connection. A "smoking gun" is that the door switches were changed in 1991 so that there are isolated contacts feeding this control unit instead of the 1990 version which shares the switch with the overhead light unit..." Hope this helps guys... Quote Share this post Link to post Share on other sites
