BeavisJem
Drive shaft weights.
Changed a CV joint because i had a strange knocking noise on the front of my car, just realised after 3 hours work putting the cv joint on that the wieght on the drive shaft has come loose, do i cut it off or try to stick it back on.
And if i can cut it off can you give me any advice
Is it rubber or metal
Whats the best way to remove it
Cheers
Beavisjem
Angle grinder, cut it off. If it was loose before you started messing about with the cv joint then theres a good chance it was the reason for the knocking.
