surfer.vr6 0 Posted May 26, 2005 i have a slight missfire on my vr6, does not make any difference what the engine speed is, but as soon as you touch the throttle it missfires slightly, also does it when letting the throttle off. recently changed ht leads any ideas? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 26, 2005 Did you change the plugs as well? Check the coilpack for any cracks and scan with VAG.COM Quote Share this post Link to post Share on other sites
surfer.vr6 0 Posted May 26, 2005 i checked the plugs and they seem fine, had the ecu read the other day with a vag 1551 only fault picked up was the crankshaft sensor cheers Quote Share this post Link to post Share on other sites
