dinger657 0 Posted May 31, 2005 got some fk coilovers, need to lower the back, i have the two hook shaped spannners, was just wandering how i do this, do i just take the wheels off and wind then down or is it a bit more complicated? cheers matt ps im a car mong not very good with tools! Quote Share this post Link to post Share on other sites
VR6 0 Posted May 31, 2005 Ok, I assume that they're already on the car? :lol: Wheel off (if necessary) and then move the bottom collar - might need to turn them both at the same time in opposite directions in order to do so. Set to desired height, tighten the collars against each other and then go for a drive. Let springs settle and re-assess height. Quote Share this post Link to post Share on other sites
chaz g60 0 Posted June 1, 2005 i just did mine and im no mechanic but found it really simple just be sure to measure the drop both sides Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted June 2, 2005 yeah its as simple as that mate , undo the lock ring and adjust to the height you want i would advise you to cover the exposed threads on the shock with some tape as the have a tight thread and get very dirty which in time makes them very difficult to adjust measure from a fixed point on the bottom of the shock to ensure the both shocks are set equal Quote Share this post Link to post Share on other sites
