Garry 0 Posted May 31, 2005 Got a SAAB 900 turbo intercooler that i'm going to try and fit to the C. Has anyone done this before?? The IC is 400mm tall x 270mm wide x 70mm deep. The hose connections are 60mm in diameter - all sounds good so far. See attached picture.... Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted May 31, 2005 Is it small enough to sit in the wing and if so will it give better cooling than a standard item? Quote Share this post Link to post Share on other sites
Garry 0 Posted June 1, 2005 I'm completely removing the OEM one from the wing and putting the new SAAB one in front of the radiator in the gap on the passenger side. Thats the plan. It is a bit bigger than the std OEM one and it'll be right in the air flow Quote Share this post Link to post Share on other sites
W3RKD 0 Posted June 1, 2005 Are you not selling the corrado now then Garry ? Quote Share this post Link to post Share on other sites
Garry 0 Posted June 1, 2005 Am I still selling her? I should really and will if anyone is interested - however after all the work I've done it'll be hard to part company Quote Share this post Link to post Share on other sites
Garry 0 Posted June 1, 2005 By the way Darren - did you take a look at that door for me yet??? Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted June 1, 2005 Keep us informed on progress, would be interesting to see how it goes and the benefits you get. Quote Share this post Link to post Share on other sites
