chrishill
Rev limiter
The sticker must have some relevance as why put it on there!??
Turn the encryption board upside down, you'll see a circuit and a component - a GAL16V8 or derivative. Search for a datasheet on this component and you'll discover what it does. Then you should be able to work out why there's a number on the EPROM.
MYOFB, There's no incryption board that the chip is mounted on if that's what you're thinking.
dr_mat, I have 9 positions on mine i'm sure but i shall double check!
Chirs
A slip being in accordance with the psychoanalytic theories of Sigmund Freud none the less if i'm not mistaken!
Nice one Chill!
Chris
