Walesy
Locks...
ok..problem 1.
I get locked in/out of my car.....
you can hear a noise as if its unlocking...but the pins dont come up and the door wont open.....will this be my pump?
heard the pump can get air locked if its locked/unlocked too quickly. could it be that?
may also be leaking?
sounds like an air leak in the system, check the pipework.
you can always climb in the boot if it fails. :lol:
first place to look is the door hing area in side the rubber sleave, start looking for holes
ok...for future reference ive narrowed it down to the drivers door handle being the culprit as ive also had probs with the elec windows. There's far too much play in the barrel when i turn the key so im pretty sure that i'm pulling the key out and leaving the barrel in the wrong position. this would give reason to why i'm having door and window closure problems. :mad:
I had a similar prob on my last C. It worked out being the circip that fits on the drivers door barrel. I replaced it, and all was fine.
