potatonet
cooling fan, still no answer
replaced switches, relays, wiring harness, temp senders. would bad after run sender cause fan to not turn on at all? also would the fact that my wiring harness is not plugged into any A/C condensor make a difference. the fan doesnt come on with the temp senders, have to be on defrost to get it on. cant go up big hills without bubbling over the coolant system, from temp reaching 235F.
also would a bad air/fuel ratio cause overheating? I get 17 mpg US gallon which is pretty low for me and I ahve black stuff all over the exhaust.... excess fuel....
race thermostat is holding my car onto the road.
