rado-steve 0 Posted June 13, 2005 Think i'm being thick, in my MK2 the were some screws hiding under little plastic clips.....On the C Nowt!!!! Also guess you can take the rear door card off after taking out the bench??? Help Guys Cheers Steve Quote Share this post Link to post Share on other sites
randal 0 Posted June 13, 2005 if i'm recalling correctly, you can just pull the bottom part of the seat out to give you better access to the panel. but, with a little jiggering you can pull the panel out with it in situ. screw at the bottom, one near the top where the seatbelt threads through and one at the back. hth randal Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted June 13, 2005 the bottom part of the seat is held in by a metal hook,to remove you need to push the bottom art of the seat towards the rear of the car and lift at the same time Quote Share this post Link to post Share on other sites
reaper1_3 0 Posted June 14, 2005 The rear bench can be abit of a tricky b****r but as dazzyvr6 says push towards rear and pull as hard as possible upwards!!! :) Quote Share this post Link to post Share on other sites
