billinjah
splines on steering column
Good luck finding a good used 1 mate,if i'm not mistaken corrados from '89 had 36 spleens on their shaft ujs and rack input shaft while '91 onwards models were reduced to 22 splines for ease of fitment.
New shaft from stealers here in sunny Rome=380euro+VAT...,used shafts 99% are worn,there's no way to change the ujs either..
..... replace the whole column and VEEDUBBED is correct on the shafts and splines, later G60's will take early VR racks.... it has been done.why do you need a bottom u joint, my C has 140k miles on it and mines in tip top shape.
i want to replace the bottom uj that goes into the rack it is availible seperately but is costly i have found a new 2l 16v one however will it fit?
i want to replace as it clicks and annoys me!!
