rmn
wires for clocks
i have been doing a bit of work on a mates car, engine out new engine in, ecu wired up, fuel pump on a new circuit.......
in the end i had a bit of an "issue" with the fusebox, which turned out to be nothing (did a continuity test and i was getting continuity from positive to negative with everything turned off, but not everything was turned off
but anyway back to my problem, car is fine and running, but the clocks are not working, what wires on ther fusebox control the clocks?
i have all main block connectors in place, but some of the unused wires are not connected and we have replaced some circuits(fuel pump)
So all i need to know is what wires go to the clocks.
thanks
Aye that helps,Thanks!!!
Ii think i have all of them connected, but not 100% yet
Does anybody know if any of the small wires are part of the clock loom?
Thanks for the diagram too!
