cheesy
Fuel Pump Wire
Had my alarm fitted today
It was noticed that the feed for the fuel pump had come off the fuse box and was just haggin, its a blue black wire
The Question is
where on the fuse box does it go?
Weve bypassed this for the time being so theres no prime just full load of fuel.
Cars a 92 G60 if that helps with wiring diagrams
Might take it to Midland VW unless someone on ere can help me out
chris
Strange,i don't remember the feed wire being blue/black,it might be the spare wire Vw included for a possible oil press gauge,the wire that terminates down near the distributer/RF sheild,the feed wire is red/yellow,but i'll check for you tomorow,what kind of terminal is on the end of that wire?,female or male spade?.
The termal is male as it sits inside one of the connector blocks which then inturn plugs into the fuse bx if that make sense
