Noiseboy16v
Heated rear windscreen not working
Hello all, I've not long had my corrado and had the first call this weekend to use the heated rear windscreen. Alas the light on the switch does not come on and the windscreen does not clear. I'm also note from the factory manual that that the heated mirrors will not work if this is the case, as they are controlled from the same switch. I have not as yet checked the fuse...any ideas though if it is not this?
Dave
8)
