bobserra 0 Posted July 18, 2005 :D Hi friends.... My 93 Corrado VR6 was just getting a new flyweel (lightened) and a new clutch, but just wen I start the engine to have some fun :twisted: (after I finish the isntalation) my car have a noise like if something is rubbing or hiting with the clutch, because this happens only when I depress the cluth after a hard acceleration (not on idle).... Any solution? :cry: Quote Share this post Link to post Share on other sites
cubed 0 Posted August 15, 2005 hello mate, i had a similar problem on my mk1 gti years ago after a new clutch and turned out to be that the fishplate sandwiched between the block and box was bent causing the flywheel to rub against it,i just removed it at the time! its just you say its when the clutch is depressed. could be the thrust bearing? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 15, 2005 Yeah, sounds like release bearing sticking - did you use a new one and plenty of grease?? - it's worth changing the part it runs on if your taking apart again... Quote Share this post Link to post Share on other sites
