SteveRobb 0 Posted July 31, 2005 Sunroof has given up the ghost. Looks like one of the slider thingies has become detched from a wire thingy. Electrics still seem to work but mechanics Kaput. Can anyone help with how to remove and replace, or point me in the right direction. Couldn't find anything specific on a search. 93 model (not sure if its early or late type? is there an easy way of telling whilst it's still on the car?) Steve Quote Share this post Link to post Share on other sites
Walesy 0 Posted July 31, 2005 when you say remove and replace...do you mean the whole unit?..if so its fairly easy...just have to remove the headlining and undo 4 or 6 bolts (( cant remember !)) ... Quote Share this post Link to post Share on other sites
andy 0 Posted July 31, 2005 Check the motor connections, if it has 3 wires I think it means its an early one, like the one I have for sale! ;-) Quote Share this post Link to post Share on other sites
SteveRobb 0 Posted July 31, 2005 Where are the motor connmections? Steve Quote Share this post Link to post Share on other sites
andy 0 Posted July 31, 2005 Under the sunroof switch panel (in the headlining), remove the light panel and there are a couple of screws holding the panel on, motor is then obvious. Quote Share this post Link to post Share on other sites
H8RRA 0 Posted July 31, 2005 get a glass sunroof out of a passat or toledo - i get them for £20 inc motor and everything and they go straight in - practice removing from a scrapper first :) Quote Share this post Link to post Share on other sites
andy 0 Posted July 31, 2005 get a glass sunroof out of a passat or toledo - i get them for £20 inc motor and everything and they go straight in - practice removing from a scrapper first :) No don't buy mine!..... :-) Is the whole mechanism the same on the passat/toledo? Quote Share this post Link to post Share on other sites
H8RRA 0 Posted July 31, 2005 it stronger and more robust and doesn't snap like the corrado one - haven;t tried swapping parts as yet cos i prefer the glass one so see no need to repair the corrado one but having pulled many apart i would be surprised if you couldnt repair a corrado one with bits from the passat Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted July 31, 2005 is the passat glass roof a tilt and slide the same ? i fancy one of those :-) Quote Share this post Link to post Share on other sites
Tekara 0 Posted July 31, 2005 Any got any pictures of a glass roof installed in a Rado ? I would mind one either. Quote Share this post Link to post Share on other sites
andy 0 Posted July 31, 2005 Does the Passat one fit straight in? Quote Share this post Link to post Share on other sites
