Skimask 0 Posted July 31, 2005 My C felt a bit underpowered recently - and a belt along the dual carraiageway it mis-fired like it was only firing on 3 cylinders. I took out the sparkplugs to give them the once over - and came across this: The central electrode is missing! the insulator moves up and down - you can see the difference in the 2 pics. I've searched around in the cylinder with a magnetic probe, but nothing appears to in there, i.e. no metal particles. A cold compression test gave 160 lb/ft which if I remember correctly is the same as a year ago. The question is - what size are the central electrodes and has this happened to anyone else on here? I still haven't ruled out the possibility that is welded to the pistopon or valve!! I don't have a spare plug to dismantle! Quote Share this post Link to post Share on other sites
