crdo16v 0 Posted August 3, 2005 Ok guys usual problem 16v kr leaking oil from distributor but i've had a new (from G & S) distributor fitted & the supposed "seal" at the base of the distributor has already been replaced once after to no avail. So why is it still leaking? when the seal was replaced this time mechanic assured me he would smear a little sealant round "the ring" (on the distributor, barf, barf!). :shock: Any sensible advice to solve this would be appreciated. Quote Share this post Link to post Share on other sites
crdo16v 0 Posted August 6, 2005 Thanks y'all for your help , after further investigation it seems likely that the leak is probably from where the distributor mates to the block/head. Hopefully this will be of use to another forum member. Quote Share this post Link to post Share on other sites
