balboa 0 Posted August 8, 2005 i have a mk2 golf gti 16v...my pride and joy,,,i am thinking of getting a supersprint manifold...advice needed on how my car would differ to the standard manifold....and has any one any idea of how much a supersprint manifold will cost, and how much im looking to get it fitted...thanks Quote Share this post Link to post Share on other sites
BigTartanJudge 0 Posted August 8, 2005 IIRC, although someone will surely correct me if I'm wrong, Supersprint 4-branch manifold's are £285 plus postage from TSR Performance. Although there may be fitment issues with them. Fitting should take around 2 hours I would have thought Hope this helps Quote Share this post Link to post Share on other sites
Baz2004 0 Posted August 8, 2005 I’ve heard they can crack when used with solid engine mounts? Not cheap by any means, it should add around 15hp from low end. Quote Share this post Link to post Share on other sites
BigTartanJudge 0 Posted August 8, 2005 Think 15BHP added is a bit optimistic TBH, maybe 8-10BHP max if the car is well set-up. Also there are fitment issues i.e. pretty big manifold so tends to knock against PAS rack and other bits in the engine bay. Hence, usually used with solid engine mounts, but again, then you MAY experience problems with the manifold cracking over time. Cheers Quote Share this post Link to post Share on other sites
g60greeny 0 Posted August 8, 2005 my mates got one on his valver it sounds well,he says it goes well to,i think he's thinking about breaking the golf to get some cash for his mk1 project Quote Share this post Link to post Share on other sites
DANG60 0 Posted August 9, 2005 would a supersprint 4 branch from a mk2 8v gti fit a corrado g60, as on of my mates is selling one and im thinking about getting it? Also would i have to have the lamba sensor fitted into the 4 branch? Also would the g60 engine run to hot for this manifold and start to cause problems with it, Just curious as to what you guys prefer- a 4 branch or and aftermarket down pipe :roll: Quote Share this post Link to post Share on other sites
Baz2004 0 Posted August 9, 2005 It should fit not sure if the lamba sensor is needed tho. Quote Share this post Link to post Share on other sites
Claret Badger 0 Posted August 9, 2005 If you want a good cheap 4 branch manifold - try Grant Motor Sport in Bristol. He sorted me out with one for under 180 quid - he (at the time i was buying) had three different types available. I had PAS - and experienced no fouling - I had no probs with "cracking" - what I did have was an improved torque range. HTH http://www.grantmotorsport.com/ Quote Share this post Link to post Share on other sites
Baz2004 0 Posted August 9, 2005 would a supersprint 4 branch from a mk2 8v gti fit a corrado g60 mk2 golf gti 16v They are talking about mrk 2 manifolds, no? :scratch: Quote Share this post Link to post Share on other sites
Claret Badger 0 Posted August 9, 2005 I need to read more carefully Mk1 project - ahhhhhhh *NURSE! Quote Share this post Link to post Share on other sites
