VEEDUBBED 0 Posted August 14, 2005 Right lads,does any 1 know why my G-charged 2.0 16valver keeps running lean??,i've changed the blue TS,air filter(K&N panel) is new and oiled,plugs are fine,throttle switches both work,timing is 6/7 degrees BTDC,ECU hose is exactly 1 meter long and O/E type,pulley on charger is O/E,lambda signal is fine,sweeps at idle/cruise but as soon as the engine gets even a hint of acceleration the leds on the meter dissapear into lean limbo,whats left?,i'm loosing my rag because i've got a theoreticly quick car that in reality won't overtake a fiat 500...,O/E chip in ECU,i can't belive that adding a super charger to a standard 2.0 9A engine would give so many problems,if i can't sort it i'm binning the charger and putting back my T3/4 turbo. The car as it stands has F@#K all acceleration,a standard uno turbo would pi$$ all over it. Quote Share this post Link to post Share on other sites
G60JAY 0 Posted August 15, 2005 Out of interest, what sort of compression ratio are you running on the engine? Quote Share this post Link to post Share on other sites
Chippie 0 Posted August 16, 2005 first get another chip, running a 2.0 16v with a chip that is ment for a 1.8 8v is just asking for trouble man. Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted August 16, 2005 get sns to burn you a chip, the 16v head will use the boost morereadily than an 8v so the engine will need more fuel for less boost than the 8v did so to speak, basically you need a rechip,, Quote Share this post Link to post Share on other sites
Dubcharged 0 Posted August 16, 2005 What was the chip you have made for? Mate if your chip was for a non force induced car and you are using it with your supercharger then you could do some real damage to your engine! Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted August 16, 2005 I don't want to sound a wizeazz but i wrote the details of my engine at least 3 times,here goes again,original 9A 2.0 16v engine,and i mean original,all of it exept a 1.8 'KR' inlet camshaft,comp. ratio is 10.5/1 pretty high i know but seeing as the G-charger can't produce more that 0.2 bar pressure on my boost gauge,momentarerly,that's not a problem,also because i've fitted a van intercooler(big). Plugs are ngk bke7s which ran fine on my old turboed 8v corrado,exhaust is all factory spec bar a hollowed out CAT,G60 pulley is stock 78?mm unit,ECU is the car's O/E digifant G60 unit with stock eeprom. Start engine,run up to operating temp,boot it in any gear and the car hits a solid wall,A/F narrow band goes full lean and the leds somtime dissappear althogther...,only when i open manually the full throttle switch after opening the idle switch will the green lights light up,with the car stationary,otherwise the gauge works perfectly,cycling at idle/criuse etc. The injectors are G60 Bosch O/E green tops. After building loads of 8v/16v turbo motors,fitting 16 valve heads on 'PG' blocks,turbo and super charging a "PG" engine,unless i'm drunk i'm NOT going to fit a NA chip into a turbocharged/supercharged engine.. As always any hints are most welcom. Quote Share this post Link to post Share on other sites
Dubcharged 0 Posted August 17, 2005 LOL sorry mate i got confused with your previous posts. So is the chip/ecu from an 8v G60? If so there's your problem. Quote Share this post Link to post Share on other sites
G60JAY 0 Posted August 18, 2005 It sounds to me like the compression ratio is to high. The knock sensor will be telling the ecu to back everything off which is why the a/f meter is going off the scale. I had a similar problem a few years ago when i was running a 2l tall block and g60 head on standard compression. I then stacked up 2 head gaskets and it solved it. See how it runs if you drop off the boost pipe and run without the supercharger. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted August 19, 2005 Nice 1 G60JAY,i'll do that tomorow,can you give me some details about your engine?,you must be the only person in Australia to have done a G60.16v. Quote Share this post Link to post Share on other sites
G60JAY 0 Posted August 24, 2005 Hi Veedubbed Yes. There are not many 16vg60 here. In fact there are not may g60 at all. Here's a few things on my engine! Mk3 golf 2l16v abf block Wiseco 83mm forged pistons 9-1 compression ratio 4340 pauter rods Lightened flywheel Balanced crank,flywheel,clutch etc Reconditioned mk2 golf kr cylinder head Hiflow custom exhaust downpipes and system Raceware headstud kit Raceware main bearing kit Eip fuel rail Rc 370 injectors Scirocco 50mm inlet manifold Uprated ignition leads Adjustable fuel pressure regulator Armtech smooth cut rev limiter Jabbasport chip Jabbasport stage 4 charger with 68mm pulley Modified airbox K&n filter Allard large front mount intercooler Custom piping allround Mocal oil cooler & stat Custom brackets for alternator,belt tensioner etc Vibratecnics rear enginemount Volks-sport front enginemount Golf rallye gearbox rebuilt with vr6 ratios Sachs uprated clutch Autocavan short shifter kit Power output around 270bhp Quote Share this post Link to post Share on other sites
