adamukcorrado 0 Posted August 22, 2005 my corrado has standard vr6 suspension which i know is getting tired but in the last few months i'm getting a loud 'clunk' from the front passenger side wheel area as i pull away, brake, or go over bumps at slow speed. there is no obvious play in any thing, but the car wanders really badly on uneven road surfaces. I thinks it's either suspension, a drive shaft, or possibly engine mount, (had solid alloy front mount fitted then clunking began fairly soon after) Any thoughts?? whats the best ways to check/ isolate problem? have tried every thing i can think of!! Quote Share this post Link to post Share on other sites
randal 0 Posted August 22, 2005 Check your wishbone bushes, I had a similar problem. I replaced the bushes in mine, but neglected to slide in the collar. The result was a random clonk in the circumstances you mention. Jacked it up, slipped the pins in and sorted. It could mean yours are up for replacement, however top mounts, drive shaft weights, engine mounts etc... could give the same symptom I'm told. Hope you find it without too much hassle mate. Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted August 22, 2005 cheers mate, last time it was worked on i was warned the bushes were knackered, looks like it might be time to invest in some powerflex bushes! Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted August 22, 2005 Are the wish bone bushes fairly easy to replace? i'm guessing it's just a matter of keeping every thing supported? need any specialist tools? Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted August 30, 2005 Fixed it!!! :D finally found the source of the clunking to be the joint on the wheel end of the front wishbone, one of the 2 bolts that hold it to the wish bone had come loose and the wheel had just enough movement to clunk!! and the best bit is it didn't cost a penny! if only all the problems on a vr6 were so easily fixed...... Quote Share this post Link to post Share on other sites
