MikeVR6 0 Posted August 31, 2005 Hi guys. Posting this message on behalf of a fellow VR6 owner in the Canary Islands. Originally posted on the Yahoo Group, but things are a little quiet there at the moment. Cheers in advance Mike Hi everyone, this is a cry for help from a fellow owner of a 1992 VR6.I have found that looking at the site has been extremely helpful to date I live in Tenerife and there are very few Corrados here as a result not many people have experience of the car.In fact even the local VW dealers mechanics .All they seem to do is replace at horrendous costs and not really diagnose so it becomes a question of elimination finally gets the answer.meanwhile the wallet has an enormous bashing My problem the car is overheating (the ambient temperature this time of year 30c) It runs at 110c when in traffic and on the minor roads in the afternoon Oil temps getting up 125c and even higher If I decide to let the car really have its legs and it wants to fly(Its so tempting but I am concerned at the moment) I have had the fan replaced, however it cuts in very briefly at 110c for about a minute then switches off !! (when I first had the car even when switched off the fan would run on for about 5mins) Is likely to be the thermoswitch?I understand the auxiliary water pump is also involved As the fan seems to work if only fleetingly Secondly I noticed the slave fan was not running and discovered the belt had come off fixed it but within a day it has come off again .It is a very thin belt, 2 things I noticed the pulley has 3 grooves on it likewise the slave pulley,the belt slots into one groove should there be more than one belt ? If not do think the belt has stretched and needs replacing as I am reluctant the put it back on for it to come off again ,,there seems to be no facility to adjust the pulleys Any advice would be most welcome regards Roger Port vintageport45#telefonica.net (replace the # with an @ if you want to mail him directly) Quote Share this post Link to post Share on other sites
RaddoDubai 0 Posted September 1, 2005 Hi Roger, I live in Dubai and its 47C outside, I am not saying I am not having problems but as a start... Change your Thermosat to one that open a lot sooner like a 74C Thermostat. Secondly drain your coolant and flush the system and add Red Line Water Wetter x 2 bottles along with the cooland/water mix. Not 2 sure about the condiation of your belts.. Lastly check your fan switches relay as mine was faulty. Good luck, Regards, Ahmed Dubai Quote Share this post Link to post Share on other sites
RaddoDubai 0 Posted September 1, 2005 By the way my car's water temp is around 110C and the oil temp is 120-124C using fully Synthetic oil Regards, Ahmed. Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted September 1, 2005 Sounds like you might need an oil cooler? Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted September 1, 2005 I'd say an oil cooler would be an essential addition in this case. I was racing home against Chrishill a little while ago from the Leeds meet and i saw 138C oil temp on the motorway, i think i could do with one too! Chris Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted September 1, 2005 Thought fully synth was to thin for C's??????? Quote Share this post Link to post Share on other sites
Taggart 0 Posted September 1, 2005 Look at some of Oilman's posts, he said not. Quote Share this post Link to post Share on other sites
