Supercharged Junkie
PAS fluid
Hi
Just changed the PAS fluid following the instruction given in the Golf/Jetta repair manual, everything went well but the pump seems noiser now is that normal ?
Used green PAS fluid from GSF, Not sure what was in there before but it wasn`t green, Black now what ever it was
Any ideas?
Thanks
Ian
Air lock probably,did you bleed the system after changing the oil?,turn steering wheel slowly from lock to lock and it should expell any air present within the rack/pipes.
1 word of caution,dont overfill the rack's fluid bottle because any oil above the MAX mark is then forced out of the red cap's breather hole,all over your engine...
Did bleed the system by first starting and the stopping the engine until all the oil was sucked into the pipes, then left it to idle for a while followed by turn the wheel lock to lock, althou i turned the wheel quickly not slowly. Most of the air bubbles in the bottle when gone, still had a little but not much.
Will do it again and see what happens
Cheers
Ian
Oh by the way, if anyone needs to know the PAS system takes about a litre of fluid. Looked everywhere to find how much oil i needed, ended up buying to bottles of green PAS fluid to be on the safe side.
