cheesy
What to Replace G60
I've decided that i'm gonna swap the engine over in my c with the rallye block out my old one as it has 50k less miles on it.
Now what i'm after is an idea of what to replace before i put the engine in & Part numbers if poss & Part Numbes of what i've listed
Have listed some parts i think, Please Add to
I'm still learning lots about this engine
* Water flange at side of engine
Housing & O Ring Seal
* 2 Sensors at front
Don't know what they are?
* New Distributor
* Plugs & Leads & Coil
* Fitting my Red Top Injectors
* Exhaust Gaskets Ready for 4 Branch Manifold
* Carbon Canister Removing
* New Starter Motor
* New Water Pump
* New Cambelt
* Oil & Filter ( Quantum Silver????
* Rear Engine Mount & Gearbx Already Uprated to Vibra Mounts
* Have a Front EIP mount To Fit
* Charger is with Daz Having the R1 Treatment
Any thing else i have missed?
Any help much apprieated
cheers chris
Don't suppose you need anything like pistons,cams,head,manifolds,exhausts,crankshafts,16valve head...Turbo+manifold??,as you can see,i've got a few spares..
