duffer
Coolant temp sensor
Yeah, need to know what engine but there are usually 2 fairly close together, one black and one blue with plugs to match, the black feeding the gauge and the blue being the important one for the ECU
Test resistance across sender pins if you think it's dead, no reading (very high)/open circuit = dead
Cold engine, remove plug and green clip and pull out sensor (turn and pull is it's difficult) - It should have an O ring which should be replaced as well.
