Valver 0 Posted September 21, 2005 Guys I have a VR6 in my Mk2 Golf (OBD1 engine from Passat). Now, we didn't put the diagnostic port in (thought we'd do it later...), and now the donor car/shell has been taken away from the breakers.... :oops: Can I use any diagnostic port from any Passat/Corrado or does it have to be a VR6 one?......Does it matter which type of plug as I think there were two types ?... Thanks for any help. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 21, 2005 It will be the later type plug, same as any late VW really except maybe the newest ones... Quote Share this post Link to post Share on other sites
Valver 0 Posted September 21, 2005 Thanks. I'll try and get one sorted. Quote Share this post Link to post Share on other sites
RW1 0 Posted September 21, 2005 If you're stuck with wires when you get a plug, PM me. Be better to get a 16 way later version as you won't need to buy / rig up an adapter with the VAG-COM lead's plug (16 way). Try and get the 16 way plug with wire still in it so that you can terminal block connect upto the ECU 4 wire loom. . Quote Share this post Link to post Share on other sites
Valver 0 Posted September 22, 2005 Thanks for the tip, RW1. Quote Share this post Link to post Share on other sites
