samm_cvr6 0 Posted September 21, 2005 Does anybody know what the positions are for these on a VR? Thanks :? Quote Share this post Link to post Share on other sites
Geo 0 Posted September 21, 2005 http://media.corrado-club.ca/tech/timingchain.pdf Go to page 18. Quote Share this post Link to post Share on other sites
samm_cvr6 0 Posted September 21, 2005 shi*, I can't open it, any ideas what I'm doing wrong? it's coming up text all gobbledigook. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 21, 2005 Works ok for me, try downloading again and this time right clicking and saving to yer local pc, then opening... If that doesn't work then update your version of adobe (acrobat) reader. Quote Share this post Link to post Share on other sites
samm_cvr6 0 Posted September 21, 2005 still not working, keeps opening it in word pad, looks like I will have to update the old acrobat...thanks tho. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 21, 2005 still not working, keeps opening it in word pad Err... yeah, re-installing/updating Adobe Reader should fix it but it sounds like your file associations have gone haywire... OPEN My Documents... Tools > Folder OPTIONS > File Types Quote Share this post Link to post Share on other sites
Geo 0 Posted September 21, 2005 Something that just occurred to me, what have you done to the engine that you need to reset the timing? Because that guide tells you how to set it with the flywheel and bottom timing cover removed. If you have just had the head off with the engine in the car it will be different, there's probably a mark on the flywheel or something..... Quote Share this post Link to post Share on other sites
samm_cvr6 0 Posted September 21, 2005 ok give me time, I'm not very good with comps, this thing is quite old, still running on 800hz, LOL, even if I have got b/band. not bad for £50 tho! LOL Quote Share this post Link to post Share on other sites
samm_cvr6 0 Posted September 21, 2005 just changing valve seals, got all the stretch bolts and gaskets, but my friend is doing it for me, he has told me he has marked it anyway, but was just checking out of curiosity. Flywheel/gearbox are still connected. Quote Share this post Link to post Share on other sites
andy 0 Posted September 21, 2005 There's a pointed arrow on one of the camshaft pulleys, you look through a hole in the pulley and line it up with a mark on the head. You set the camshafts relative to each other ideally by using a tool (but any bit of sheet metal will do) in the opposite end of the camshafts, there's an offset notch which is set horizontally and the tool locks the camshafts together. The crankshaft can either be set by the marks on the flywheel or by the tiny notch on the pulley at the other end, lined up with the mark on the block. There is more to setting the timing than this, but that's where the marks are. Have a look at the How-To by 2cc too. Quote Share this post Link to post Share on other sites
