sharlie1982
Heater Problems
I bought my 1992 K Plate Corrado G60 4 months ago. Now with the weather becoming colder, the fact that the heater does not put out any warm air, is getting annoying to say the least. :x
Where do I start with solving this? Is it going to be a new matrix, or are there other possibilities? :?
Please help. :(
Welcome to the Forum, use the search as there's been quite a few posts re. heater probs & it isn't necessarily the matrix.
If you can't sort it after checking the posts, find a good mechanic who will methodically check the various potential causes.
On my valver the problem of no heat was caused by some mumpty (not me) fitting the by-pass valve upside down.
Good luck.
sharlie1982, when you move the slider from hot to cold does it feel like it's connected to anything?? - it should be fairly stiff and you should here a flap moving across (if not the the cable may have snapped - a fiver from VW)
