bix
Steel g60 pulley, no slip?
Translated from http://www.ls-cartec.de/g60.htm
G60 - loader wheels steel
- 58, 60, 62, 65, 68, 70, 72mm
- High-grade steel
- for high achievements
- no belt slip
Stock No.: 1513 (request motor vehicle type and loader wheel size indicate)
What do we think, surely it must slip a bit, ima try one out I think cant go wrong for 67€, mine slips like fcuk!
i wouldn't bother if i were you. if the belts slipping that much you must be using the incorrect belt length.
65mm pulley which is a bit dodgy, so need a new one anyway really, I'm pretty sure the belt is 1750mm (got it from darren with 68mm pulley) but I've got a 1725mm one now which should help if I can get it on!
