Ronan
Which number fuse is...
My fog switch doesnt work, ie the light doesnt even come on, so I'm guessing the fuse has blown. Can anyone tell me which fuse controls this please?
Thanky muchly
1 Headlight, low beam, left 10
2 Headlight, low beam, right 10
3 Instrument panel lights, license plate lights 10
4 Rear window wiper 15
5 Wiper/washer, front 15
6 Fresh air fan 20
7 Tail lights, side marker light, right 10
8 Tail lights, side marker light, left 10
9 Rear window defogger 20
10 Foglights 15
11 Headlight, high beam, left 10
12 Headlight, high beam, right 10
13 Horn, radiator fan run-on 10
14 Back-up lights, washer jet heaters 10
15 Electronic ignition, idle stabilizer, deceleration fuel shut off 10
16 Dash warning lights, glove box light, cassette storage light, rear spoiler adjustment control unit 15
17 Emergency flasher switch, turn signals 10
18 Fuel pump 20
19 Radiator coolant fan, A/C 30
20 Brake lights 10
21 Interior lights, cigarette lighter, digital clock,
rear spoiler adjustment 15
22 Radio 10
fuse 10 mate :-) the fuse list is on the fuse box cover ;-)
6 Fresh air fan 20
10 Foglights 15
18 Fuel pump 20
20 Brake lights 10
22 Radio 10
Mine isn't! Thanks for the help mate I shall take a look tomoro...
are you mate , on the underside of the shelf you take out to get to the fuse box ?
Yeah thats how you get to it?
i know :roll: but the list is on there , take a look when you take it off :wink:
yep,normally? got the fuse positions on that bit that you remove.
im guessing a little here but,i think if your fog switch isnt lighting up then its your headlight switch thats dodgy.
i think(again :roll: ) that the fuse is for the power from the fog switch to the fogs,worth checking the fuse anyway i suppose.
OK Gixxer cheers, sory i didnt quite know what you were getting at. I honestyl don't think it's there...
Yeah Riley I have a dodgy headlight switch, I guess I will try the fuse and if that doesnt work, then I will see what happens when I replace the headlight switch.
Cheers guys, didnt think anyone else would be up this late, maybe you;re bothin as bad a mood as i am!
aye,im feeling a bit pi$$ed off,eased by a friend called budweiser :lol:
as far as the fog switch m8,im just thinking the fogs only work with the lights on,so the headlight switch must feed the fog switch,and then>fuse>fogs...
along those lines anyway i think :?:
Hi all.
Rather than start a new thread I'll open this oldie up.
New car, 1991 G60 and a few gremlins. All as above. My fogs front or rear don't work. The light on my switch does work. So upon investigation I fit a new headlight switch still no joy. At the fuse box I find a bridge wire between fuse's 9 and 10. I remove said wire and no light at the fog switch???
So any ideas where next?
What relays work with the lights? I have a Bentley on CD but noway can I get it to work on XP n tried many web browsers.. Seems have to purchase the real thing. :roll:
As ever cheers
