mk1-corrado
Oil Sensor- part numbers?
Hey all,
just a quick one, i have just started to get a leak from the sensor mounted to the top of the oil filter housing.
Does anyone know what the part number is? Or maybe the GSF part number as there are loads to choose from. Colour looks white-ish to me.
Cheers
ive just bought new pressure and temp senders,was a bit of a ball ache to find them.
the oil temp one on the filter head,furthest from the block is vw only.
1ho 919 563.£15 quid!
oil pressure,filter head,nearest block.
vw number,068 919 081.
low oil pressure switch,side of cylinder head.
vw number,056 919 081d.
neil.
Cheers for that, i shall try and order one from local dealer tomorrow. It looks like it leaking from the single wire white top one on top of the oil filter housing, as you look down in front of rad.
Thanks again neil
no probs m8,mine was doing the same :lol:
just replaced em all though.
edit:yours is a g60 aint it m8? :oops:
ahh bugger!
may be the wrong part numbers then,gimme 2 secs and ill have a look,what year is it?
neil.
