bix
Water leak, around pump
Have a water leak around the pump, but as you cant really see a lot without taking the charger off, I wanna buy the stuff ready, to just wack on, so I'm thinking, new pump and thermostat, any other likely things ity could be?
Cheers
Yep, it will be leaking where the impeller meets the pump housing - get a complete new pump from VW, stat, plastic housing, bolts for housing and pulley and G12+...
