VWci 0 Posted October 14, 2005 What do i need to change in 2.0 16v corrado front brakes to g60 brakes ? Do i only need dics and calipers ?? and is it easy swap ? .... cheers...;) Quote Share this post Link to post Share on other sites
corradophil 3 Posted October 14, 2005 I used calipers and carriers from a mk3 Golf GTI, and G60 discs and pads. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 14, 2005 Yep, as above, calipers/carriers, 280mm discs, pads and idealy new hoses too Quote Share this post Link to post Share on other sites
Phil K 0 Posted October 14, 2005 Is it a straight forward swap? Just sent my Dad down to the scrappy (he was going anyway :lol: ) to look for a set 8) Quote Share this post Link to post Share on other sites
corradophil 3 Posted October 14, 2005 Yes, straightforward, remove calipers from carriers as normal. Then the carriers un bolt from the hub, re-assemble all new items and bleed! Theres no tweaking or modifying of any components, they are all interchangable. Quote Share this post Link to post Share on other sites
Phil K 0 Posted October 14, 2005 sweeeeeet... 8) Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted October 14, 2005 I thought the calipers were the same and it was just the carriers and the discs that were needed? My 'rat originally had 256mm fronts and was converted to the 280mm by the previous owner - he said all he changed were the carriers and the discs... Quote Share this post Link to post Share on other sites
mk2_20vt 0 Posted October 14, 2005 I'm also using MK3 calipers with G60 280mm disks. I have had to buy new hydraulic hoses as the calipers have a banjo fitting on instead of the screw in type fitting. Quote Share this post Link to post Share on other sites
corradophil 3 Posted October 14, 2005 My Mk3 calipers had the thread fitting, not banjo! I had to replace the calipers too, because the discs are thicker. The only way I could get away with using my original calipers (which I wanted too do) would have been to file some of the friction material off the pads - not at all ideal. Quote Share this post Link to post Share on other sites
mk2_20vt 0 Posted October 14, 2005 My Mk3 calipers had the thread fitting, not banjo! I think they changed over around '95ish. Anybody with VR6 have banjo fittings on theirs as well? Quote Share this post Link to post Share on other sites
VWci 0 Posted October 14, 2005 :thumbleft: :thumb right: Quote Share this post Link to post Share on other sites
Geo 0 Posted October 14, 2005 I always thought it was the 288s that had the banjo fitting and all the 280s were threaded. Quote Share this post Link to post Share on other sites
leon 0 Posted October 14, 2005 It is possible to use the 16v calipers but not ideal at all. You can either machine the caliper to take the disc and pads or you can just change one pad at a time and when it wears a bit replace the other side. Or as mentioned get the pads skimmed by 1mm each when new. Definitely far from ideal and I wouldnt use it myself. G60 calipers and carriers arent dear these days anyway. Loads of them now running around on Brembos so should be easy to pick up. Quote Share this post Link to post Share on other sites
Baz2004 0 Posted October 14, 2005 I always thought it was the 288s that had the banjo fitting and all the 280s were threaded. I think the early 8V mrk 3s had the threaded fittings the later 16Vs had the banjos. Quote Share this post Link to post Share on other sites
mistrall 0 Posted October 17, 2005 makes loads of diference :) Quote Share this post Link to post Share on other sites
