Broken G60 0 Posted October 17, 2005 Dear All, Please can you help me get to work in the morning? My G60 has developed the endearing habit of kangarooing down the road then dying when I drive it. It doesn't seem to do it above 40mph and once I've done a long drive on a dual carriageway, it seems to be fine until I next drive it. I noticed at the same time that the mpg reading shows as 99.9. If only it were true. When I first tried to drive home this evening it jumped and stalled about 30 times, but once I reached the dual carriageway it seemed to be fine. I had a look through some threads about lift pumps failing and poor electrical connections, but none seemed to exactly match my situation. If anyone had some thoughts I would be very grateful. Thanks for your time, Sam Quote Share this post Link to post Share on other sites
W3RKD 0 Posted October 17, 2005 lambda / co pot / ecu vac hose would be the first 3 things i check Quote Share this post Link to post Share on other sites
MickeyT 0 Posted October 18, 2005 had a similar prob on mine turned out to be the distributor Quote Share this post Link to post Share on other sites
Broken G60 0 Posted October 26, 2005 Thanks for your help guys! Turns out all it needed was a new fuel filter. If only everything in life was this simple. Quote Share this post Link to post Share on other sites
