sambog60
g60 idle problems
Hi guys,
Just got a 92 raddo g60 and having some running probs. When it is started from cold it idles at about 1500rpm but drops off when it starts heating up but then can vary between 800 - 1300rpm at idle and just appears to be a bit lumpy, but when you are driving and you lift off the throttle and put the clutch in for changing gear etc.. the revs don't drop off they do fall but very slowly, this is my first g60, and maybe i am just been a bit fussy but i just want it to be right, could it be the isv, any other ideas?
thanks for any help
Could be the isv needing a good clean out, but i'd say your throtle cable is sticking or the throtle is sticking, spray some WD40 around the throttle spindles and see if your cable moves freely when disconected.
Could be the blue temp. sensor at the front of the block. There are two sensors plugged into the water hose that runs from the block to the rad. Disconnect the blue sensor with the engine running and the revs should drop. If not then the sensor is dodgy and should be replaced. Only a few quid from GSF.
