Supercharged
[KB] Torque Settings and Bolt Sizes (Suspension and Brakes)
The information from this thread has now been compiled into a Wiki article, so I've locked this thread and un-stickied it.
Brakes
Front
Carrier bolts 125Nm 17mm
Caliper to carrier 35Nm 13mm into 15mm
Splash Sheild and ABS sensor 10Nm
Rear
Carrier bolts 65Nm
Dust sheild 60Nm
Wheels Bolts 110Nm
Brake hoses = 14mm
MC to servo 20Nm 13mm
Bleed Nipples 9/11mm
Suspension
Front
Upper nuts 60Nm
Lower Bolts/Nuts 95Nm
Rear
Axle Bolts 70Nm
Bottom bolts/nuts 70Nm
Rear strut top nut 15Nm
Top Nuts 25Nm below washer, 15Nm above
Misc Drivetrain...
Front Hub Nut 265Nm
Axle shaft to wheel bearing housing 90Nm + 45 degrees
Track rod to rack 70Nm (use threadlock) 32mm
Track rod end to Wheel bearing housing 35Nm 19mm
Track Rod/TRE adjustment - 7/8"
Driveshaft to Gearbox 45Nm
Ball joint to wheel bearing housing 45Nm
Ball joint to control arm/wishbone 35Nm
ARB link 25Nm
Most of the above information is from the US Robert Bentley manual and the forum takes no responsibility for mistakes etc.
If anyone has any corrections/additions etc please post in this thread and I will update the first post and this will eventually be moved into the Knowledge base.
